LPC 812 - debugging running device
1,003件の閲覧回数
vojtechhavlicek
I would like to know, if there is any way to debug running MCU LPC812? I have source code, project, original bin file and I just need to debug MCU without flashing device with new (old) firmware (I suspect that ther could be some problem with corrupted image on flash).
Other way would be to download flash from MCU to PC. Is it possible?
Thank you for your reply.
Vojta
タグ(3)
4 返答(返信)
908件の閲覧回数
jeremyzhou
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
Another way would be to download flash from MCU to PC. Is it possible?
-- Yes, it's possible and you can learn how to do it by referring to
https://learn.adafruit.com/getting-started-with-the-lpc810/programming-the-lpc810-with-flash-magic
TIC
908件の閲覧回数
converse
Senior Contributor V
It is described in the MCUXpresso User Guide - attach to running target (section 12.3.2 in the 11.0.0 version)
908件の閲覧回数
vojtechhavlicek
thank you for your reply. To edit launch configuration I have to double click on file ProjectNameDebug.launch as mentioned in user guide? Project was imported from LPCXpresso 7.4.0. and when I click on the debug launch configuration in file tree it opens only text editor. There is no menu.
908件の閲覧回数
vojtechhavlicek
Ok,
no problem, new launch configuration file has been created with first debug.
