LPC 24xx ISP locked
LPC 24xx ISP locked
655 次查看
michalmatejka
We have LPC 2468 with internal flash and need to reprogramme with our code by ISP. Probleme is, that IC is locked and setted security...Is a way to un-lock device, erase  and burn new code. We use Flash Magic ..
标签 (2)
490 次查看
CarlosCasillas
Hi Michal,
You mean the CRP has been implemented? if CRP1/2 is set, you can use FlashMagic to erase the flash.
If CRP3 is set, ISP mode only can be entered by user code.
Hope this will be useful for you.
Best regards!
/Carlos
