I'm getting a hard fault when jumping from my bootloader to the app. It's on an LPC1519 and the bootloader resides at 0x0000 - 0x1FFF, while the application starts at 0x2000. I'm using LPCXpresso.
I've seen this question asked and apparently answered somewhere else but none of the solutions proposed worked for me. Here is the code I use for the jump:
SCB->VTOR = (0x2000);
asm volatile("ldr r0, =0x2000"); // Code start address
asm volatile("ldr sp, [r0]");
asm volatile("ldr r0, [r0, #4]");
//asm volatile("add r0, r0, 1"); // tried this as I read address has to be odd for thumb
asm volatile("mov pc, r0");
//asm volatile ("bx r0"); // tried this as I read is not safe to load PC
If I debug it, everything goes fine until the PC load or BX, where it goes to the hard fault loop.
Anything can point the right direction?
Cheers
Edited: If I edit the application 'ld' file to have the main as entry point, as below, then it works, but I'd like to know what the difference makes skipping the ResetISR function (the bootloader ran it anyways).
/*ENTRY(ResetISR)*/
ENTRY(main)
Update:
I found that it all works if I comment out the function call Board_SetupClocking() in Board_SystemInit, that is called by SystemInit, called by ResetISR. This way I have the initialisation from Flash and the clock was already initialised by the SBL.
More precisely, the offending lines inside Board_SetupClocking are the call to Chip_SetupXtalClocking and the always dangerous while (!Chip_Clock_IsUSBPLLLocked()) {}. Just if anyone else stumbles on this.
Still wondering why an apparent repeated clock setup would cause a problem ?!?!
Another bit of a worry is that this makes me to have two software frame versions, standalone with clock setup and bootloader-launched without.
Also, I noticed there are some USB clock initialisation. My LPC1519 hasn't got USB. I'm not sure but I'm just assuming that initialisation has no effect for that MCU.
That's at least a side-topic. Anyways, the question is direct and easy, I first flashed the application with offset, like writing data on flash, then I flashed the bootloader then when reset it runs and jumps to the app. Remember not to use the 'erase all flash' option. There are more elegant ways, like the one pointed above here by Carlos.
Hi Juan,
I don't think that is the correct fix, it will only work correctly if the debugger is attached. I would recommend you to use the LPC1700 secondary USB bootloader as reference:
http://cache.nxp.com/docs/en/application-note/AN10866.zip
This is the function used by the bootloader to jump to the application:
__asm void boot_jump( uint32_t address ){
LDR SP, [R0] ;Load new stack pointer address
LDR PC, [R0, #4] ;Load new program counter address
Have you tried debugging your application startup code and see if ts is another instruction inside this function causing the hardfault?
Hope it helps!
Carlos Mendoza
Technical Support Engineer
Thanks, Carlos. Could you tell me what difference makes your code:
instead of mine? I see it functionally identical.
Yes, I first debug then ask. It crashes right after the PC register is loaded. I checked the r0 register has the right value beforehand (the ResetISR address). But in this case I don't think debugging helps as I have the application flashed and what I debug is the bootloader, so the debugger doesn't know anything about the application after the "mov pc". I wonder if there is a way of debugging two independent applications.
Facts so far are:
- The bootloader executes fine until it jumps to the ResetISR [seen with debugger]
- The bootloader does jump to the ResetISR [reason below]
- If at the beginning of the ResetISR function I call main, then it works, but I'm skipping the RAM initialisation
Because of the above, I think my problem is with the RAM initialisation, but I can't see why copying from flash to RAM causes a hang.
Hi Juan,
Yes, they are functionally identical. There could also be a problem with the SystemInit function, I would recommend you to debug both the bootloader and the application by adding the following command to your debug Run Commands:
add-symbol-file C:\\Users\\b38285\\Documents\\MCUXpressoIDE_10.0.0_344\\workspace\\MK64FN1M0xxx12_Project_2\\Debug\\MK64FN1M0xxx12_Project_2.axf 0x80000
The address 0x80000 corresponds to the first flash section of the second project which was previously flashed to the MCU:
Hope it helps!
Carlos Mendoza
