How to use Image authentication API ?
737 次查看
slou26
We need to check signature of an application located after the bootloader. We think use the image authentication api to do that.
We tried to call  "skboot_authenticate" function without success ( HardFault ). Do you have an example for this ?
Tks
666 次查看
soledad
Unfortunately, we don't have an example like you need, however you can check the following application notes:
https://www.nxp.com/docs/en/application-note/AN12283.pdf
https://www.nxp.com/docs/en/application-note/AN12527.pdf
Sol
