On LPC11E14 I use PIO0_12 and PIO0_14 as encoder inputs. As such these are both configured as digital inputs. I would like to add broken cable detection, which would involve placing an analog voltage (VCC/2) on PIO0_12 and PIO0_14. Then these pins would also connect to an analog input simultaneously. Are there any consequences to placing the VCC/2 level on the digitally configured inputs? Higher current drain perhaps? Latch up?
You only need to be careful with voltage and current maximum values. Regarding the voltage, if you configure the pin as a digital input, then this pin takes as logical “high” level a 0.7VDD voltage value and for “low” level 0.3VDD voltage value.
For example if VDD=3.3v the level high minimum is 2.31v, and the maximum “low” level is 0.99v, for 1.8v you are in the threshold voltage.
The max. current supported for digital pins is 10nA.
I hope this helps,
Sol
Please check the following values from the datasheet.
I hope this helps,
Sol
