I am using KSDK 1.3.0, Processor Expert, custom PCB with MK02FN64VLH10 controller.
I've been trying to get the com port working for 2 days now...I need some guidance..
Used PE to set up the uart and the program crashes when executing this:
UART_DRV_SendData(0,&data,1u);
After a day and a half, I deleted all the PE stuff, and copied the example from the drivers examples\uart\uart_non_blocking/main.c
Set some definitions / variables, and compiles fine, but it crashes at the same code, UART_DRV_SendData...
Here is the code I copied from the example, the line it crashes on (step over and never returns) ends with ##########
int Uart_Setup(void) // this was main..
uint8_t rxChar, txChar;
uint32_t byteCountBuff = 0;
// Initialize variable uartState of type uart_state_t
uart_state_t uartState;
// Fill in uart config data
const uart_user_config_t uartConfig = {
.bitCountPerChar = kUart8BitsPerChar,
.parityMode = kUartParityDisabled,
.stopBitCount = kUartOneStopBit,
.baudRate = 38400
// Enable clock for PORTs, setup board clock source, config pin
hardware_init();
// Initialize the uart module with base address and config structure
UART_DRV_Init(BOARD_DEBUG_UART_INSTANCE, &uartState, &uartConfig);
// Inform to start non blocking example
byteCountBuff = sizeof(buffStart);
UART_DRV_SendData(BOARD_DEBUG_UART_INSTANCE, buffStart, byteCountBuff); // crashes here #########
// Wait until transmission is finished
while (kStatus_UART_TxBusy == UART_DRV_GetTransmitStatus(BOARD_DEBUG_UART_INSTANCE, NULL)){}
// Inform user of what to do
byteCountBuff = sizeof(bufferData1);
UART_DRV_SendData(BOARD_DEBUG_UART_INSTANCE, bufferData1, byteCountBuff);
while(true)
// Call received API
UART_DRV_ReceiveData(BOARD_DEBUG_UART_INSTANCE, &rxChar, 1u);
// Wait until we receive a character
while (kStatus_UART_RxBusy == UART_DRV_GetReceiveStatus(BOARD_DEBUG_UART_INSTANCE, NULL)){}
// Echo received character
txChar = rxChar;
UART_DRV_SendData(BOARD_DEBUG_UART_INSTANCE, &txChar, 1u);
FYI.
Crashes in startup_MK02F12910.s at the below line when I pause
b DefaultISR // ################ always is here when I pause | |
.size DefaultISR, . - DefaultISR |
/* | Macro to define default handlers. Default handler |
* | will be weak symbol and just dead loops. They can be |
* | overwritten by other handlers */ |
.macro def_irq_handler handler_name | |
.weak \handler_name | |
.set \handler_name, DefaultISR | |
.endm |
解決済! 解決策の投稿を見る。
Hello Rande,
Please be sure enable the UART clock .
And please run into the function UART_DRV_SendData() to check when run to which code , it crash.
And you can also try this function : UART_DRV_SendDataBlocking().
After these , if it still can not work , please send your project to me !
Hope it helps
Alice
Hello Rande,
Hope it helps
Alice
Hi Alice,
If I need to post this on NXP site I will..let me know..but if not, here
is the issue:
The UART is sending bytes, but it repeatedly sends when not called..
Here is the "send a byte" routine and some pics of the tera term output..
CODE: I made a loop and toggled an LED each time I called the UART TX.
PROBLEM is the UART continually sends, I only want to send one byte, can
you see what is wrong?
Here is the code:
void SendSerialChar(byte data)
uint32_t i; //for tests
byte DataToSend=0x30; // for test
// below loop is used for testing
while(1)
if(DataToSend>0x39)
DataToSend=0x30;
}else
DataToSend++;
TP6_TGL; // this is a test LED
UART_DRV_SendData(0, &DataToSend, 1u);
__ASM("nop"); //nop is here for a breakpoint..prog gets here
about once a second.. .
for(i=0;i<10000000;i++) // delay is about a second or so per 10
million..
__ASM(" nop");
This is the PIC of tera Term recording the data:.. Each time the LED
toggles the number being sent changes..
Thank you,
Rande Newberry
H-ITT, LLC, a Hyper-Interactive Teaching Technology Company
420 Shearer Blvd.-Cocoa, FL, 32922
PH: 888-322-0089
rande@h-itt.com
Hi Rande,
I think you enable the TX callback, if yes, there is a bug on the KSDK UART driver,
you need to fix it , and then re-build the KSDK lib , then build your project .
The fix method is
Add these code into the function of "void UART_DRV_IRQHandler(uint32_t instance)" in the file of "fsl_uart_driver.c"
++uartState->txBuff;
--uartState->txSize;
after add , it will like this :
also if you use receive function , also fix it :
Hope it can helps you
Alice
Hi Alice,
I disabled callback in PE and everything is OK!
Please know that I am just beginner, and using the default is my first
choice, you helped me a lot!
Thank you very much.
Rande Newberry
PH: 888-322-0089
rande@h-itt.com
Hi Rande,
OK, welcome !
Alice
Hi Alice,
The problem is caused by something else in the project.
I created a new project last night and with PE I created the UART
exactly like I did in the main project and it works fine.
So, I'll back out some functions until I isolate the cause.
Thank you
Rande Newberry
PH: 888-322-0089
rande@h-itt.com
