Let´s start with FreeMASTER!
What is it FreeMASTER?
FreeMASTER is a tool with variety GUIs in one offered free. FreeMASTER is a user-friendly real-time debug monitor and data visualization tool
−GUI can be easily extend by multimedia content (charts) and user-modified content (possible mix user´s data with default values)
− offers access to target variables, symbols and data types
− access over UART, CAN or USB with target-side driver and over BDM
− possibility to direct control via variable modifications
− addresses parsed from ELF file or provided by target (TSA)
− scope graphs with real-time data in [ms] resolution
− recorder visualization transitions close to 10[us] resolution
FreeMASTER features
Real Time Monitor
-Displaying variable values in various formats (Text, Real-Time waveforms, High-speed recorded data)
Control Panel
- Direct variable value settings and variable stimulation, scribtable in JScript or VBScript
Demonstration Platform
- Demostration embedded app by HTML pages, display simultaneous real-time data monitoring
Easy Project Deployment
- Entire project saved to a single file
FreeMASTER communication
There are two types of communication. It is possible to communicate via Direct RS232 or selected Plug-in Module.
In short:
SCI, UART
USB – CDC – Kinetis, ColdFire V2
CAN
JTAG (56F8xxx only)
BDM – Kinetis, PowerPC, ColdFire, HCS with Segger, P&E Micro, CMSIS-DAP…
FreeMASTER usage
Real-time debugging - FreeMASTER allows users to debug applications in true real-time through its ability to watch variables. Moreover, it allows debugging at the algorithm level, which helps to shorten the development phase
Diagnostic tool - FreeMASTER remote control capability allows it to be used as a diagnostic tool for debugging customer applications remotely across a network
Demonstrations - FreeMASTER is an outstanding tool for demonstrating algorithm or application execution and variable outputs.
Education - FreeMASTER may be used for educational purposes. Its application control features allow students to play with the application in demonstration mode, learning how to control program execution.
FreeMASTER description of the environment
The FreeMASTER window is divided into 4 parts - Project Tree, Detail View Pane, Commands and Variable Watch Grid.
Project Tree is the project, New Block is a root of the project, New Scope is similar to classical Oscilloscope. Scope periodically reads variable values and plots them in real-time. It is limited by the serial communication speed. The recorder is also monitoring and visualising variable values, but the change is much faster. The recorder is running on target board and variable values are sampled into memory buffer on the board and then these sampled data are downloaded from the board to FreeMASTER.
Detail View Area is dynamically changes depending on content which is selected in Project Tree. Detail View Tab can be control page, algorithm block description, scope, recorder or another HTML document whose URL is defined in the Scope or Recorder properties.
Commands window is list of commands to send, Variable Stimulus - is the list of defined variables for the defined time.
In Variable Watch Grid contains the list of watched variables.
Supported devices
FreeMASTER download and support
The installation package you can download from the Official website:
FreeMASTER Official website
www.nxp.com/freemaster
You can ask us on Community or you can create new SR according to https://community.freescale.com/docs/DOC-329745
More about FreeMASTER
FreeMASTER Official Website
https://www.nxp.com/freemaster
Using FreeMASTER
https://cache.freescale.com/files/microcontrollers/doc/reports_presentations/FREEMASTERPRESENT.pdf
FREEMASTER:  Remote Server Tutorial
https://community.freescale.com/docs/DOC-103293
Tutorial: FreeMASTER Visualization and Run-Time Debugging
https://mcuoneclipse.com/2013/08/24/tutorial-freemaster-visualization-and-run-time-debugging
Let´s continue with reading! Let´s start with KSDK!
コメント
Excellent :smileywink:
Do you have an example using SDK 2.0 and k64?
I'll be your fan if you do.:smileyhappy:
Jordan
I use  the "Kinetis KM3x_256 MCU Three-Phase Metering Reference Design"  as metering  part of my 3-Ph power protect module.
Now I need to read out the Freemaster  TSA table from another MCU ( Keaz64) .
Could you  provide any example or document ?
Is FreeMaster following the XCP protocol? If not, how is it similar or different with XCP?
FreeMASTER uses it is own specific protocol.
I'd recommend you to check this document for more details:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN2471.pdf
Hope it helps,
Stan
Thanks Stan. Appreciated.
Is there any possibility in freeMaster GUI to save the oscilloscope data and re-load it at a later date? (e.g. offline analysis)
I only find option to export an image file.
Or do I miss something?
Yes, you can save the data captured by oscilloscope/recorder. There is a settings "Data Capture Setup" where you can specify the file the data is saved into:
Hope it helps.
Stan
I tried that, but it does not work.
The files are always generated at C:\Users\xxxx\AppData\Local\Temp instead of the path provided here.
Am using Windows 10 and and latest version of freeMaster.
%3CLINGO-SUB%20id%3D%22lingo-sub-1124908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%BE%E3%81%9A%E3%81%AFFreeMASTER%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%20font-family%3A%20Arial%3B%20color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%22%3EFreeMASTER%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23717171%3B%20font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3EFreeMASTER%E3%81%AF%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AAGUI%E3%82%921%E3%81%A4%E3%81%AB%E3%81%BE%E3%81%A8%E3%82%81%E3%81%9F%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%80%81%E7%84%A1%E6%96%99%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82FreeMASTER%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%95%E3%83%AC%E3%83%B3%E3%83%89%E3%83%AA%E3%83%BC%E3%81%AA%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%BC%E3%82%BF%E8%A6%96%E8%A6%9A%E5%8C%96%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%20.56pt%3B%20margin-left%3A%20.33in%3B%20text-indent%3A%20-.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84(%E3%83%81%E3%83%A3%E3%83%BC%E3%83%88)%E3%82%84%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E4%BF%AE%E6%AD%A3%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84(%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A8%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E5%80%A4%E3%81%AE%E6%B7%B7%E5%9C%A8%E3%81%8C%E5%8F%AF%E8%83%BD)%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81GUI%E3%82%92%E7%B0%A1%E5%8D%98%E3%81%AB%E6%8B%A1%E5%BC%B5%E5%8F%AF%E8%83%BD%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E5%A4%89%E6%95%B0%E3%80%81%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E5%9E%8B%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E5%81%B4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FUART%E3%80%81CAN%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFUSB%E7%B5%8C%E7%94%B1%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3BDM%E7%B5%8C%E7%94%B1%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%A4%89%E6%95%B0%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AB%E3%82%88%E3%82%8B%E7%9B%B4%E6%8E%A5%E5%88%B6%E5%BE%A1%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EELF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8B%E3%82%89%E8%A7%A3%E6%9E%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88(TSA)%E3%81%8B%E3%82%89%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%5B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Ems%5D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%E5%88%86%E8%A7%A3%E8%83%BD%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%81%AE%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%90%AB%E3%82%80%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%82%B0%E3%83%A9%E3%83%95%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%80%E3%81%AE%E5%8F%AF%E8%A6%96%E5%8C%96%E3%81%AF10%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eus%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5D%3C%2FSPAN%3E%E3%81%AE%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%A7%A3%E5%83%8F%E5%BA%A6%3C%2FSPAN%3E%E3%81%AB%E8%BF%91%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148163_148163.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148163_148163.png%22%20style%3D%22width%3A%20449px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117986iD3BBF3FC54656468%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148163_148163.png%22%20alt%3D%22148163_148163.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20449px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F14206iD7FD836DFD1831E4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148164_148164.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148164_148164.png%22%20style%3D%22width%3A%20461px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117987iDC88234944DD7D44%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148164_148164.png%22%20alt%3D%22148164_148164.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20461px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55377i13CD8EC2AD84B5DD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSTRONG%3EFreeMASTER%E3%81%AE%E7%89%B9%E5%BE%B4%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23f9b500%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014pt%3B%22%3E%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23262626%3B%22%3E%E3%83%BB%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%E5%A4%89%E6%95%B0%E5%80%A4%E3%82%92%E6%A7%98%E3%80%85%E3%81%AA%E5%BD%A2%E5%BC%8F%E3%81%A7%E8%A1%A8%E7%A4%BA(%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%80%81%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E6%B3%A2%E5%BD%A2%E3%80%81%E9%AB%98%E9%80%9F%E8%A8%98%E9%8C%B2%E3%83%87%E3%83%BC%E3%82%BF)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23f9b500%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014pt%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%91%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%20font-size%3A%2014pt%3B%22%3E-%20%E7%9B%B4%E6%8E%A5%E5%A4%89%E6%95%B0%E5%80%A4%E8%A8%AD%E5%AE%9A%E3%81%A8%E5%A4%89%E6%95%B0%E5%88%BA%E6%BF%80%E3%80%81JScript%E3%81%BE%E3%81%9F%E3%81%AFVBScript%E3%81%A7%E8%90%BD%E6%9B%B8%E3%81%8D%E5%8F%AF%E8%83%BD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23f9b500%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014pt%3B%22%3E%E3%83%87%E3%83%A2%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E-%20HTML%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%88%E3%82%8B%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%A2%E3%83%97%E3%83%AA%E3%80%81%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%E3%83%87%E3%83%BC%E3%82%BF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%E7%9B%A3%E8%A6%96%3C%2FSPAN%3E%E3%81%AE%E5%90%8C%E6%99%82%E5%AE%9F%E8%A1%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23f9b500%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014pt%3B%22%3E%E7%B0%A1%E5%8D%98%E3%81%AA%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%B1%95%E9%96%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20bold%3B%22%3E-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%85%A8%E4%BD%93%E3%82%92%201%20%E3%81%A4%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E4%BF%9D%E5%AD%98%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-weight%3A%20normal%3B%20font-size%3A%2018pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%22%3EFreeMASTER%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%22%3E%E9%80%9A%E4%BF%A1%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23717171%3B%20font-weight%3A%20normal%3B%20font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF2%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82Direct%20RS232%E3%81%BE%E3%81%9F%E3%81%AF%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E9%80%9A%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20font-weight%3A%20normal%3B%20font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E8%A6%81%E3%81%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%20font-size%3A%2012pt%3B%22%3ESCI%E3%80%81UART%3CBR%20%2F%3EUSB%20%E2%80%93%20CDC%20%E2%80%93%20Kinetis%E3%80%81ColdFire%20V2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%20font-size%3A%2012pt%3B%22%3ECAN%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EJTAG%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E(56F8xxx%20%E3%81%AE%E3%81%BF)%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EBDM%20%E2%80%93%20Kinetis%E3%80%81PowerPC%E3%80%81ColdFire%E3%80%81HCS%20with%20Segger%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%E3%80%81P%26amp%3BE%20Micro%E3%80%81%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3ECMSIS-DAP%20...%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148165_148165.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148165_148165.png%22%20style%3D%22width%3A%20854px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117988i97FA2E29D2805C43%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148165_148165.png%22%20alt%3D%22148165_148165.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20854px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55032i686C17D5E778E0D6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%3CSTRONG%3EFreeMASTER%E3%81%AE%E4%BD%BF%E3%81%84%E6%96%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2392d050%3B%20font-weight%3A%20bold%3B%22%3E%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EFreeMASTER%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%E3%81%AF%E3%80%81%E5%A4%89%E6%95%B0%E3%82%92%E7%9B%A3%E8%A6%96%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E7%9C%9F%E3%81%AE%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E9%96%8B%E7%99%BA%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E3%81%AE%E7%9F%AD%E7%B8%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2392d050%3B%20font-weight%3A%20bold%3B%22%3E%E8%A8%BA%E6%96%AD%E3%83%84%E3%83%BC%E3%83%AB%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EFreeMASTER%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E6%A9%9F%E8%83%BD%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E7%B5%8C%E7%94%B1%E3%81%A7%E9%A1%A7%E5%AE%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%81%A7%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%A8%BA%E6%96%AD%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2392d050%3B%20font-weight%3A%20bold%3B%22%3E%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EFreeMASTER%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%E3%81%AF%E3%80%81%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%A8%E5%A4%89%E6%95%B0%E5%87%BA%E5%8A%9B%E3%82%92%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%84%AA%E3%82%8C%E3%81%9F%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2392d050%3B%20font-weight%3A%20bold%3B%22%3E%E6%95%99%E8%82%B2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EFreeMASTER%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%20%E3%81%AF%E6%95%99%E8%82%B2%E7%9B%AE%E7%9A%84%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%88%B6%E5%BE%A1%E6%A9%9F%E8%83%BD%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E5%AD%A6%E7%94%9F%E3%81%AF%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A9%A6%E3%81%97%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E5%AD%A6%E3%81%B6%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%22%3EFreeMASTER%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%22%3E%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%AE%E8%AA%AC%E6%98%8E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%20font-size%3A%2018pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148166_148166.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148166_148166.png%22%20style%3D%22width%3A%20900px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117990i77DD0F9C48D5544F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148166_148166.png%22%20alt%3D%22148166_148166.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_21.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_21.png%22%20style%3D%22width%3A%20900px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F14207i30DB8A77DD0216C8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_21.png%22%20alt%3D%22pastedImage_21.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3EFreeMASTER%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%84%E3%83%AA%E3%83%BC%E3%80%81%E8%A9%B3%E7%B4%B0%E3%83%93%E3%83%A5%E3%83%BC%E3%83%9A%E3%82%A4%E3%83%B3%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%81%E5%A4%89%E6%95%B0%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%82%B0%E3%83%AA%E3%83%83%E3%83%89%E3%81%AE4%E3%81%A4%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AB%E5%88%86%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3EProject%20Tree%3C%2FSTRONG%3E%20%E3%81%AF%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%80%81%20%3CSTRONG%3ENew%20Block%3C%2FSTRONG%3E%20%E3%81%AF%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%80%81%20%3CSTRONG%3ENew%20Scope%3C%2FSTRONG%3E%20%E3%81%AF%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AB%E4%BC%BC%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AF%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E5%A4%89%E6%95%B0%E5%80%A4%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%80%81%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%A7%E3%83%97%E3%83%AD%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E9%80%9A%E4%BF%A1%E9%80%9F%E5%BA%A6%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%E5%A4%89%E6%95%B0%E5%80%A4%E3%81%AE%E7%9B%A3%E8%A6%96%E3%81%A8%E8%A6%96%E8%A6%9A%E5%8C%96%E3%82%82%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%A4%89%E5%8C%96%E3%81%AF%E3%81%AF%E3%82%8B%E3%81%8B%E3%81%AB%E9%AB%98%E9%80%9F%E3%81%A7%E3%81%99%E3%80%82%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%80%E3%81%AF%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%A4%89%E6%95%B0%E5%80%A4%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89FreeMASTER%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E8%A9%B3%E7%B4%B0%E8%A1%A8%E7%A4%BA%E9%A0%98%E5%9F%9F%3C%2FSTRONG%3E%20%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%84%E3%83%AA%E3%83%BC%E3%81%A7%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E5%8B%95%E7%9A%84%E3%81%AB%E5%A4%89%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3E%20%5B%E8%A9%B3%E7%B4%B0%E3%83%93%E3%83%A5%E3%83%BC%5D%20%E3%82%BF%E3%83%96%3C%2FSTRONG%3E%20%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%80%81%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%AA%AC%E6%98%8E%E3%80%81%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%80%81%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20URL%20%E3%81%8C%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%88%A5%E3%81%AE%20HTML%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FSTRONG%3E%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AF%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A7%E3%80%81%20%3CSTRONG%3E%E5%A4%89%E6%95%B0%E5%88%BA%E6%BF%80%3C%2FSTRONG%3E%20-%20%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%9F%E6%99%82%E9%96%93%E3%81%AE%E5%AE%9A%E7%BE%A9%E6%B8%88%E3%81%BF%E5%A4%89%E6%95%B0%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E5%A4%89%E6%95%B0%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%82%B0%E3%83%AA%E3%83%83%E3%83%89%3C%2FSTRONG%3E%E3%81%AB%E3%81%AF%E3%80%81%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E5%A4%89%E6%95%B0%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%3CSTRONG%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148175_148175.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148175_148175.png%22%20style%3D%22width%3A%20857px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117993iF039472AAC30D6CF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148175_148175.png%22%20alt%3D%22148175_148175.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22supported_devices.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22supported_devices.png%22%20style%3D%22width%3A%20857px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55460i59E868EDAD2D61A9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22supported_devices.png%22%20alt%3D%22supported_devices.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%3CSTRONG%3EFreeMASTER%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%E5%85%AC%E5%BC%8F%E3%82%A6%E3%82%A7%E3%83%96%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3EFreeMASTER%20%E5%85%AC%E5%BC%8F%E3%82%B5%E3%82%A4%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.nxp.com%2Ffreemaster%22%20target%3D%22test_blank%22%3Ewww.nxp.com%2Ffreemaster%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148177_148177.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148177_148177.png%22%20style%3D%22width%3A%20474px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117996iC3F3DFC5C367EE36%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148177_148177.png%22%20alt%3D%22148177_148177.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20474px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55501i1E38BE8A5A035251%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222001%22%20data-containertype%3D%2214%22%20data-objectid%3D%22329745%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329745%22%20target%3D%22_blank%22%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%A7%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%8B%E3%80%81https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-329745%3C%2FA%3E%3C%2FSPAN%3E%20%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84SR%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148176_148176.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148176_148176.png%22%20style%3D%22width%3A%20457px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117999i1413492C5A354299%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148176_148176.png%22%20alt%3D%22148176_148176.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20457px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F14202iBF72C0B1AE4BDE14%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%3CSTRONG%3EFreeMASTER%E3%81%AE%E8%A9%B3%E7%B4%B0%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22language%3A%20en-US%3B%20line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%20.56pt%3B%20margin-left%3A%20.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3EFreeMASTER%E5%85%AC%E5%BC%8F%E3%82%B5%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.nxp.com%252Ffreemaster%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Ffreemaster%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%2014pt%3B%22%3EFreeMASTER%E3%81%AE%E4%BD%BF%E3%81%84%E6%96%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fcache.freescale.com%252Ffiles%252Fmicrocontrollers%252Fdoc%252Freports_presentations%252FFREEMASTERPRESENT.pdf%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcache.freescale.com%2Ffiles%2Fmicrocontrollers%2Fdoc%2Freports_presentations%2FFREEMASTERPRESENT.pdf%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%2014pt%3B%22%3EFREEMASTER%3A%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222019%22%20data-containertype%3D%2214%22%20data-objectid%3D%22103293%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103293%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-103293%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%3A%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EFreeMASTER%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%81%AE%E8%A6%96%E8%A6%9A%E5%8C%96%E3%81%A8%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fmcuoneclipse.com%252F2013%252F08%252F24%252Ftutorial-freemaster-visualization-and-run-time-debugging%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fmcuoneclipse.com%2F2013%2F08%2F24%2Ftutorial-freemaster-visualization-and-run-time-debugging%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3E%E7%B6%9A%E3%81%8D%E3%82%92%E8%AA%AD%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86!%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222019%22%20data-containertype%3D%2214%22%20data-objectid%3D%22330924%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-330924%22%20target%3D%22_blank%22%3EKSDK%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86!%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1124908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFreeMASTER%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%9F%E3%83%91%E3%82%B9%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%B8%B8%E3%81%AB%20%3CEM%3EC%3A%5CUsers%5Cxxxx%5CAppData%5CLocal%5CTemp%3C%2FEM%3E%20%E3%81%AB%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EWindows%2010%E3%81%8A%E3%82%88%E3%81%B3%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AEfreeMaster%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20364px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F69251i7C7779541DCE3380%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFreeMASTER%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%2F%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%A7%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E8%A8%AD%E5%AE%9A%E3%80%8D%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20365px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F69487iC935A76EC8924E0D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20402px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F69555i4FBFCF57493BD4C5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFreeMASTER%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3EfreeMaster%20GUI%E3%81%A7%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%80%81%E5%BE%8C%E6%97%A5%E5%86%8D%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F(%E4%BE%8B%3A%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E5%88%86%E6%9E%90)%3C%2FP%3E%3CP%3E%E7%94%BB%E5%83%8F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%97%E3%81%8B%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E4%BD%95%E3%81%8B%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFreeMASTER%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%82%B9%E3%82%BF%E3%83%B3%E3%80%82%E6%84%9F%E8%AC%9D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFreeMASTER%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3EFreeMASTER%E3%81%AF%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fmicrocontrollers%2Fdoc%2Fapp_note%2FAN2471.pdf%22%20title%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fmicrocontrollers%2Fdoc%2Fapp_note%2FAN2471.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcache.freescale.com%2Ffiles%2Fmicrocontrollers%2Fdoc%2Fapp_note%2FAN2471.pdf%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFreeMASTER%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EFreeMaster%E3%81%AFXCP%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81XCP%E3%81%A8%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BC%BC%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFreeMASTER%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-382459861%22%20id%3D%22toc-hId-1304072289%22%3E%E7%A7%81%E3%81%AF%E3%80%813-Ph%E3%83%91%E3%83%AF%E3%83%BC%E3%83%BB%E3%83%97%E3%83%AD%E3%83%86%E3%82%AF%E3%83%88%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%BB%E3%83%91%E3%83%BC%E3%83%84%E3%81%A8%E3%81%97%E3%81%A6%E3%80%8CKinetis%20KM3x_256%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A93%E7%9B%B8%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%BB%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--1424994602%22%20id%3D%22toc-hId--503382174%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1062518231%22%20id%3D%22toc-hId-1984130659%22%3E%E6%AC%A1%E3%81%AB%E3%80%81%E5%88%A5%E3%81%AEMCU(Keaz64)%E3%81%8B%E3%82%89FreemasterTSA%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--744936232%22%20id%3D%22toc-hId-176676196%22%3E%E4%BD%95%E3%81%8B%E4%BE%8B%E3%82%84%E8%B3%87%E6%96%99%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1742576601%22%20id%3D%22toc-hId--1630778267%22%3E%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFreeMASTER%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23373e4d%3B%20font-family%3A%20helvetica%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23e0edff%3B%22%3E%E5%84%AA%E3%82%8C%E3%81%9F%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23373e4d%3B%20font-family%3A%20helvetica%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23e0edff%3B%22%3ESDK%202.0%20%E3%81%A8%20k64%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E4%BE%8B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23373e4d%3B%20font-family%3A%20helvetica%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23e0edff%3B%22%3E%20%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%95%E3%82%A1%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23373e4d%3B%20font-family%3A%20helvetica%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23e0edff%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23373e4d%3B%20font-family%3A%20helvetica%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23e0edff%3B%22%3E%E3%83%A8%E3%83%AB%E3%83%80%E3%83%B3%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎04-28-2016 12:39 AM
更新者:
