KL03 RTOS Startup code
937 次查看
ericeckenrode
I have a question about the below code in my KL03 project.
I'm not using an RTOS.  In this case is it ok to remove the code?
  ** Don't write any code pass this
line, or it will be deleted during code generation. **
  /*** RTOS startup code. Macro
PEX_RTOS_START is defined by the RTOS component. DON'T MODIFY THIS CODE!!! ***/
  #ifdef PEX_RTOS_START
PEX_RTOS_START();
/* Startup of the selected RTOS. Macro is defined by the
RTOS component. */
  #endif
  /*** End of RTOS startup code.  ***/
  /*** Processor Expert end of main routine.
  for(;;){}
DON'T WRITE CODE BELOW!!! ***/
} /*** End of main routine. DO NOT MODIFY
THIS TEXT!!! ***/
/* END main */
Eric
738 次查看
BlackNight
If you don't have an RTOS (like FreeRTOS or MQX) added to the project as Processor Expert component, then you can remove that
PEX_RTOS_START();
And if you have anyway an RTOS, simply start it yourself like with vTaskStartScheduler() in FreeRTOS.
Erich
739 次查看
BlackNight
PEX_RTOS_START();
Erich
