Hi @cqhcau
As the reference manual says the only one FTM module fulfils the complete functionalities:
“one 6-channel FTM with full functions and two 2-channel FTM with basic TPM functions”.
This is why I recommend you to use the FTM2 module.
B.R.
VaneB
Hi @cqhcau
From the information you are providing, I advise you to try to disable the write protection (WPDIS = 1), this can let you modify the write protected bits during the process, this would allow you to change the channel value in the task.
B.R.
VaneB
Hi @cqhcau
B.R.
VaneB
