I am looking for a development Kit to run a small video in an LCD window. I am mostly a hardware engineer and it has been 6 years since I developed code. I am thinking the K70 is where I am starting. The demo online does what I want. I also want a USB peripheral. The question is what is the best way to learn how to do this large task. I am also looking into Easy GUI or embedded wizard.
解決済! 解決策の投稿を見る。
You can also check the LPC based solution:
https://www.lpcware.com/content/blog/frame-video-player-lpc1788
Luis
Hi Luis
I looked at both K70 and the MX6 and I decided to go with the MCIMX6UL mostly on your recommendation and the fact that the chip cost less than the K70. I want to . use the following kits to get started
LCD8000-43T
i.MX6UltraLite Evaluation Kit (EVK)
What kind of compiler does this require
I would like to follow a path that is well explored. You mentioned an embedded Linux solution. Would that have some sample software that I could use?
My goal is to use the kits to get more familiar with the processes.
Does the MQX require an operating system? I like the prices on this part better.
MQX is an operating system. www.nxp.com/mqx
eGUI is the graphic library. www.nxp.com/egui
eGUI doesn't need an Operating system.
Luis
Hi Daniel Morley ,
We don't have a video player solution for the K70. It is possible with some limitations to play videos. Cortex M4 doesn't have enough performance for running video decoders.
https://www.youtube.com/watch?v=n-asY6CR6nk
You can check with Motomic. A better solution would be the MCIMX6UL running Linux.
Luis
Luis
I decided to ax the video. Sounds too complicated. Do you offer a LCD color display interface solution. Defiantly trying to work with out an operating system.
You can use eGUI with MQX or bare metal. Use the latest sources:
https://github.com/Gargy007/eGUI
Check also this: https://community.freescale.com/docs/DOC-330064
Luis
