Hi, Am unable to execute my complete WDT ISR in K20D kinetis microcontroller , System is getting reset before few instructions in WDT interrupt are executed, how to increase this limitation
Customer can add WDOG time-out value during the system initialization phase.
The WDOG register modification should within WCT (watchdog configuration time).
Wish it helps.
Ma Hui
No. The WCT just watchdog configuration time. You could modify the WDOG timeout register value in code start up phase.
Then you could get enough time to execute the WDOG interrupt handle routine when WDOG interrupt happens.
Wish it helps.
Ma Hui
1> Customer could modify below registers about watchdog time-out value:
Watchdog Time-out Value Register High (WDOG_TOVALH) &
Watchdog Time-out Value Register Low (WDOG_TOVALL)
2> Customer also could feed the watchdog in watchdog interrupt service routine at very beginning.
3> Customer also could modify the watchdog clock source from bus clock to LPO clock to extend the watchdog time-out time.
Wish it helps.
Ma Hui
