TWR-K60N512 (Problems with first steps)
1,142件の閲覧回数
admin
Specialist II
Hello!
I have bought TWR-K60N512. I also have installed:
1)IAR 5.50.6
2)MQX 3.7 and kwickStik_Patch
So I have problems at 4'th point of "Quick start":
I have found "build_libs.eww" and done everything with it. But when I had opened "TWR-K60N512_Quick_Start_Demo.eww" with IAR, it wrote:
1)The project 'TWR-K60N512_Quick_Start_Demo' contaains the unknown tool 'PEMICRO_ID'
2)Invalid driver (/driver) option
3) Invalid processor (/proc) option
4)No kernel to load
5)An error occured trying ti initialize the debugger. Debugging will not be available in this session
What should I do?
716件の閲覧回数
anthony_huereca
You'll need to use IAR 6.10 or later. Earlier versions of IAR don't have support for OSJTAG, which is the built-in debugger on the tower boards.
You could alternatively use a JLink to program the board (which is supported in IAR 5.50), but you'd have to re-configure the project settings since opening the IAR 6.10 projects in IAR 5.50 corrupts the settings.
