I am using OM2385/FS001 development kit for research, but after dropping the microcode file SF_KL43Z_OL2385_Demo_55.2MHz.s19 onto the FRDM-KL43Z icon on the host PC and turning on the board, it will report error on the terminal emulator, as shown below:
And I check the demo project SF_KL43Z_OL2385_Demo download from Embedded SW for SIGFOX Based on OL2385 , find that the ACK frame return the error code sfErrUnknownSpiCommand after sending change network standard command, as shown below:
The problem confused me a lot, could somebody teach me how to launch correct microcode file and run the board successfully.
Hi @yogaCHEN,
What is the module version that you are working on?
Could you please comment on the line SetupSigfoxDriver? The Set up is sending a new command that the previous versions do not support.
Please let me know your findings.
Mario
