Porting SPI Driver to Keil RL-ARM System: UnInit
647件の閲覧回数
tfrauenrath
My task is to port a NXP SPI driver delivered with Keil RL-ARM to my Kinetis K60 system. Finlay I want to talk to SD cards in SPI mode. I do this step by step. My next task is the UnInit routine.
This is the original NXP UnInit:
/* Return SSP interface to default state. */
static BOOL UnInit (void) {
  IODIR0 &= ~(1<<20);
  PINSEL1 &= ~0x000003FC;
  SSPCR1 = 0x0000;
  SSPCR0 = 0x0000;
  SSPCPSR = 0x00;
  return (__TRUE);
This my first trial for the Kinetis UnInit:
/*--------------------------- UnInit ----------------------------------------*/
PORTD->PCR[11] = PORT_PCR_MUX(1);     /* Alt 1 for GPIO*/
PORTD->PCR[12] = PORT_PCR_MUX(1);     /* Alt 1 for GPIO*/
PORTD->PCR[13] = PORT_PCR_MUX(1);     /* Alt 1 for GPIO*/
PORTD->PCR[14] = PORT_PCR_MUX(1);     /* Alt 1 for GPIO*/
SIM->SCGC3 &= ~SIM_SCGC3_SPI2_MASK;    /* Disable SPI2 gate clocking        */
SIM->SCGC5 &= ~SIM_SCGC5_PORTD_MASK;   /* Disable PORTD gate clocking        */
return (__TRUE);
Do you think this is applicable for SD card access via SPI?
I will discuss the other routines in other threads because of a better overview. I will post the final driver, because Keil provides only samples for SDHC mode for memory cards for the Kinetis system.
Thank you
0 返答(返信)
