[Pe035]: #error directive: MKW01Z4 memory map
1,090件の閲覧回数
thiagolehrcompa
Hello everyone!
I'm using IAR 7.5 version. I'm coding from the radio utility pack from the page of MRB-KW01, and I'd like to use SDK 1.3 SPI library. In order to do this, I've gotten a SPI example (spi_polling_example_master) and I've tried to include all the headers and .C needed in my project.
But, when I try to rebuild all, appears this error to me:
Fatal Error[Pe035]: #error directive: MKW01Z4 memory map: There is already included another memory map. Only one memory map can be included. $PROJ_DIR%\...\....\....\MKW01Z4\include\MKW01Z4.h 78
The part of the code is:
/* Check if another memory map has not been also included */
#if (defined(MCU_ACTIVE))
  #error MKW01Z4 memory map: There is already included another memory map. Only one memory map can be included.
#endif efined(MCU_ACTIVE)) */
I thought that it'd be something about duplicate files, but it isn't. I also put in the preprocessor tab defined
CPU_MKW01Z128CHN4
and
MRB_KW01
Any ideas what could be this problem?
Thanks for the help and attention!!
Thiago
3 返答(返信)
780件の閲覧回数
Carlos_Musich
Hi Thiago,
are you having problems with the KSDK SPI examplelocated in this path C:\Freescale\KSDK_1.3.0\examples\mrbkw01\driver_examples\spi\spi_polling\master\iar?
Or problem is with your own project that you created based on this example?
I have just loaded the .eww file in C:\Freescale\KSDK_1.3.0\examples\mrbkw01\driver_examples\spi\spi_polling\master\iar then build ksdk_platform_lib and finally spi_polling_example_master without problems
So, if your problem is the example itself I guess that the example was modified or corrupted, or maybe your installation. In this case I recommend reinstall to go back to normal.
If the problem is with an example you created please let me know the steps you followed to clone the project.
Carlos
780件の閲覧回数
thiagolehrcompa
Hi Carlos,
I'm sorry, but I still couldn't solve my problem. Actually, the problem I'm facing is to join the HAL library (SPI, I2C, etc, from SDK 1.3) to the SMAC library (which I made my program to send packets between two boards, from Radio Utility package).
In SMAC libray, I saw that there is this memory map added: MKL26Z4.h, while the HAL library has another memory map, MKW01Z4.h (which makes more sense than the another one included, since the board's name is KW01, anyway).
When I merge the files into one project, it appears the error "There is already included another memory map. Only one memory map can be included." However, I can't remove any header file, otherwise it gives me other errors.
Do you have any idea of what could I do about it?
Thanks for your attention!
Thiago
780件の閲覧回数
thiagolehrcompa
Hello Carlos,
Sorry for the late reply. Actually, I took the Radio Utility example, and tried to take all the SPI library files and add in Radio Utility folder. Basically, I put the part of the code that I was interested (from spi_polling_example_master) in and, as long as I was compiling, the compiler showed lots of errors - most part were about missing files. So, I was adding the right files, until the last problem that I got was this one from my first post.
I don't know if is that possible to do.
I'm trying more specifically use SMAC and SPI in the same project.
Thanks for your time,
Thiago
