MKL25Z128-How can I reset MCU
946 次查看
陈欣
I want to reset MCU by software,How can I control the register?
Thanks;
657 次查看
LuisCasado
You can check in the Cortex M0+ :
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0484c/DDI0484C_cortex_m0p_r0p1_trm.pdf
AIRCRa Application Interrupt and Reset Control Register in the ARMv6-M Architecture ReferenceManual.
Checking in the ARMv6-M RM :
https://silver.arm.com/download/ARM_and_AMBA_Architecture/AR585-DA-70000-r0p0-00rel0/DDI0419C_arm_ar...
    In the AIRCR register, WO - SYSRESETREQ bit. :  Writing 1 to this bit asserts a signal to request a reset by the external system.
This register is in address : 0xE000ED0C
So you should write the bit [2] SYSRESETREQ in that address to request a SW reset. Take care with the rest of the bits value, modify only that bit.
Luis
658 次查看
LuisCasado
Luis
