What is the correct name of MK22FN128VDC10 package, MAPBGA 121 8*8*0.5 P0.65 or 121 XFBGA? is it the same?
Solved! Go to Solution.
Hi Sergey,
Of course, you can refer to the application note.
And I think it's a very helpful file.
Ping
Hi Sergey,
Ping
Thank you
the last question - can I consider AN3846 as PCB Design Guidelines for this package?
Hi Sergey,
The kind package of the MK22FN128VDC10 IS XFBGA, 121 8*8*0.5, and I've also attached the package description and mechanical drawing.
Hope it helps.
Ping
Hi Ping,
I saw this document, but package there called MAPBGA
Hi Sergey,
After verified the kind of parameters that the file illustrates, I think it's a doc issue, the title should be the XFBGA instead of the MAPBGA.
And I'll report the issue to the doc team later.
Ping
