KL16 low power crystal startup time
629件の閲覧回数
chipweller
I am using a MKL16Z256VLH4 with a 32768 Hz crystal running in lower power mode (HGO=0).  The datasheet lists the typical crystal startup time (tsct) as 750 ms, and I do see something like that.
My question is what should I assume for the maximum time. Currently I am using 1 second. The processor is running at 3.0V (+/-4%) and the expected die temperature range is 15C to 45C.
タグ(1)
480件の閲覧回数
Paul_Tian
Hi, Weller
Sorry, we do not provide max. value of startup time. But I think you can use this 1 second value first. Thanks.
Best Regards
Paul
