KL03 Voltage Reference Start-up Time
1,428 次查看
bradsundstrom
Section 30.5 in the KL03 reference manual (rev 4) indicates that there is a settling time that you must wait before using the voltage reference to ensure accurate results. The reference manual says that this time is specified by Tchop_osc_stup, which is defined in the datasheet. I can find no mention of the Tchip_osc_step parameter in the datasheet for KL03.
  Am I missing something, or should this be published in the datasheet?
From section 30.5:
When the chop oscillator is enabled, the settling time of the internal bandgap reference is defined by Tchop_osc_stup (chop oscillator start up time). You must wait this time (Tchop_osc_stup) after the internal bandgap has been enabled to ensure the VREF internal reference voltage has stabilized.
Brad
1,204 次查看
Jorge_Gonzalez
Hello Brad:
I just received confirmation that the value of Tchop_osc_st is maximum 35 ms. This will be included in the next revision of the datasheet.
Regards!
Jorge Gonzalez
1,205 次查看
Jorge_Gonzalez
Hello Brad:
Regards!
Jorge Gonzalez
1,203 次查看
Jorge_Gonzalez
Hello Brad:
I am sorry for the time with no response. Not sure if the information is still relevant for you but I am checking it anyway. I will post a response as soon as I get it.
Regards!
Jorge Gonzalez
