K82 VBAT Register File size
988 次查看
deniscollis
Contributor V
According to the documentation  the VBAT register file is 128 bytes:
However, the MCU descriptor header file (MK82F25615.h) in MCUXpresso defines it as 8 * 4 = 32 bytes:
typedef struct {
__IO uint32_t REG[8]; /**< VBAT register file register, array offset: 0x0, array step: 0x4 */
} RFVBAT_Type;
What is it?
Denis
标记 (5)
894 次查看
RaRo
Hello @deniscollis,
As you mentioned the VBAT register should be __IO uint32_t REG[32] instead of __IO uint32_t REG[8] to meet what is stated in the K82 Sub-Family Reference Manual.
Let us double check, if there is a special reason for it. At the meantime, we are letting the team in charge to know about this. Thank you for feedback.
Best regards, Raul.
987 次查看
deniscollis
Contributor V
I think it may be a copy/paste error in  MK82F25615.h.  The preceding definition was the System Register File, which is defined identically to RFVBAT but is, indeed, 32 bytes:
/** RFSYS - Register Layout Typedef */
typedef struct {
  __IO uint32_t REG[8]; /**< Register file register, array offset: 0x0, array step: 0x4 */
} RFSYS_Type;
I assume I can safely change the VBAT Register definition to occupy 128 bytes:
typedef struct {
__IO uint32_t REG[32]; /**< VBAT register file register, array offset: 0x0, array step: 0x4 */
} RFVBAT_Type;
I have no idea how to report errata in MCUXpresso SDKs. If someone from NXP is reading this, please let me know.
895 次查看
RaRo
Hello @deniscollis,
Best regards, Raul.
757 次查看
RaRo
Hello @deniscollis,
After double check, K82 Sub-Family Reference Manual information is correct. We have already reported this issue to the team in charge of the SDK.
Thanks again for your feedback.
Best regards, Raul.
