K61 FLEXCAN has no DMA support
897 次查看
benjaminschroed
I've been looking at the Kinetis K series processors, and it appears the CAN interface (FLEXCAN) has no DMA support, only interrupt.  Is this correct, or is there a workaround to be able to utilize DMA, specifically for Rx?
Thanks.
标记 (2)
666 次查看
miduo
Yes, you are correct. For Kinetis K61, FlexCAN is not a DMA request source and there has no way to use like that.
667 次查看
miduo
666 次查看
benjaminschroed
Thank you for the confirmation.
