I read on the datasheet that this particular MCU that I am using does not have an NVM part. I plan to use the upper portion of flash as data storage. Without NVM, is it still possible to configure this portion as data storage? I tried doing it nevertheless. The first time I write it is successful. However the second time, the debugger hangs. I traced the problem that it returns at function FLASH1_Main().
Specifically at line:
if(((DataToPrg & DataToPrgMask) & (~CurrentFlashPrgUnitData)) > 0U) {
DeviceDataPrv->CurrentErrorFlags |= LDD_FLASH_MULTIPLE_WRITE_ERROR;
return;
As you can see the error is multiple error. Is there any workaround to this problem given that I will not change the MCU with NVM? If yes, How should I do it?
By the way linker file I tried configuring the portion where I want to write as RWX but to no avail.
I am using Codewarrior 10.2 and MQX 3.8.
Thank You.
I had exactly the same problem, this was happening because the sector that you were trying to write to was not erased. The PE generated code does not erase the sector for you prior to writing to it, you have to erase it yourself. I hope this helps someone else.
By the way I copied the settings on this link Erasing Flash sectors in KL25 on the Freedom Board.
I allocated space for flash component as well.
I'll paste my functions below.
bool readInternalFlash(u32 address, u8 * data, u16 len)
FLASH1_Read(flash_Ptr, address, data, len); // Start reading from the flash memory
do {
FLASH1_Main(flash_Ptr);
OpStatus = FLASH1_GetOperationStatus(flash_Ptr);
} while (!((OpStatus == LDD_FLASH_IDLE) | (OpStatus == LDD_FLASH_FAILED)));
if (OpStatus == LDD_FLASH_FAILED)
return false;
return true;
bool writeInternalFlash(u32 address, u8 * data, u16 len)
FLASH1_Write(flash_Ptr, data, address, len);
while (!DataWrittenFlg) {
DataWrittenFlg = FALSE;
if (FLASH1_GetOperationStatus(flash_Ptr) == LDD_FLASH_FAILED)
return false;
readInternalFlash(address, data, len);
return true;
bool eraseInternalFlash(u32 address, u16 len)
if (FLASH1_Erase(flash_Ptr, address, len) == ERR_OK)
return true;
else
return false;
