K60 RTC Vbat supply
K60 RTC Vbat supply
1,082 次查看
marcosmarcoso
we are using kinetis K60 (MK60DN512VLQ10). And we would like to use now an external battery to supply the RTC.
As we are working with VDD=1.8V, can the RTC work directly from a 3V battery?
In the datasheet K60P144M100SF2V2, I see that VBAT operating requirements are 1.71 to 3.6V, but I don't see any restriction respect VDD, is there any?
Thank you
best regards
标记 (3)
666 次查看
EMontanez
Marcos,
K series products have separate VDD and VBAT domains. Both those domains support 1.71-3.6V supply ranges. The two domains can operate from independent supplies.
In summary, you can separate VBAT from VDD and operate it from a battery. :smileyhappy:
Eduardo
667 次查看
EMontanez
Marcos,
Eduardo
