MCU:MK22FN512
RAM大小:两个64K组成128KB
问题:
程序中开辟了很多全局数组,如:
static double total_tem_data_y[128*8];
static double total_tem_data_z[128*8];
IAR编译链接OK后,出来的RAM空间6K readony data memory;70K readwrite data memory;
然后我再开辟一个全局数据 static double total_tem_data_x[128];128个double也才1K,加上之前的6K和70K也才77K的总大小。
编译链接后就报错了
Solved! Go to Solution.
Hello Liubin,
You can try to declare the SRAM as one "single" area instead two parts.
Please refer to this thread :
Help me out of this IAR compile Error : cannot fit "Block .bss"
Hope it helps
TIC
Hello Liubin,
Hope it helps
TIC
Thank you very much sir, it worked.
