K20 based MK20FN1M0VMD12 PORT flexbus control drive strength question
827 次查看
sherry_zahid
I am using a K20 based MK20FN1M0VMD12
I am using the flexbus to connect to an SRAM chip. I am using the following pins for control signals to the SRAM
Pin nameALT ModeFunction
PTD1ALT 5FB_CS0_B
PTC11ALT 5FB_RW_B
PTB19ALT 5FB_OE_B
PTC17ALT 5FB_BE31_24_B
PTC16ALT 5FB_BE23_16_B
I am using these pins in the ALT 5 mode, I need to have high drive strength on these control signals.
I found in the datasheet that bit 5 of the pin control registers need to be set to 1 for high drive strength.
PORTx_PCRy[n]
x = port letter
y = pin number
n = register bit#
My question is, although I am operating in ALT 5 mode for these pins, can I still enable high drive strength on these pins by setting the corresponding (bit 6) PCR bits? i.e.
FB_CS0_BPORTD_PCR1[6] = 1
FB_RW_BPORTC_PCR11[6] = 1
FB_OE_BPORTB_PCR19[6] = 1
FB_BE31_24_BPORTC_PCR17[6] = 1
FB_BE23_16_BPORTC_PCR16[6] = 1
Will these pins have high drive strength if I set bit 6 of these registers to high(1)? (I am using ALT5 function of these pins for flexbus SRAM control signals)
Thank you for your time.
693 次查看
jeremyzhou
Hi Sherry,
It's ok to set the bit 6 to 1 when pin work in the ALT5 mode.
The Driver Strength Enable (DSE) is valid in all digital pin muxing modes, definitely contains the ALT5.
Hope it helps.
Ping
694 次查看
jeremyzhou
Hi Sherry,
Hope it helps.
Ping
693 次查看
sherry_zahid
Thanks Jeremyzhou,
That answers my question perfectly.
