Infinite loop using BMT180 with I2C
566件の閲覧回数
juancamilomonto
Im trying to get data from the sensor BMT180 using KL27 and the I2C protocol. I can obtain it but when I wanted to do an infinite loop to acquire information the sensor give me the same data, it doesn't change, but when I disconnect and connect all the system, the data changes.
Juan Camilo Montoya
タグ(2)
474件の閲覧回数
Jorge_Gonzalez
Hello Juan:
Please provide details about your issue (code, scope images, IDE, ...) so we can help you. Usually you can compare the frames you get with a scope to those that the slave device is expecting from the master.
Regards!
Jorge Gonzalez
