Hypothetically speaking, if you wanted to use a FRDM-K64 on a outer space flight what components would be most likely to fail in the environment of space ? Are there space rugedized components from NXP which could be used to replace the onboard components ? What about the PCB board itself. How would space affect the PCB ?
Randy
Hello Randy,
Unfortunately, we do not have any aerospace compliant MCU, the nearest one on the K-Series devices is KEA automotive MCUs. Please check link below.
Arm Cortex-M0+|Kinetis KEA 32-bit Automotive MCUs | NXP
In addition, I recommend you to read the following article about our Power Architecture Processors that are compliant with DO-254.
Felipe
Something at Micro Semi's Space page might lead you in a direction:
Applications - Space | Microsemi
While very dated still has some interesting things to say:
Dialectrics for Space Vehicles:
