How to solve the error "Fatal error- Failed to read CPUID for Cortex device" for MK60FN1M0VLQ12 controller ?
rajkumar_yerraj
I am getting an error "Fatal error- Failed to read CPUID for Cortex device" when i try to program the controller using IAR embedded work bench. Before programming, i erased the controller memory by clicking Erase Memory in IAR Workbench.
IAR Embedded Workbench -> Project Settings -> Download ->Erase Memory.
After this erase, i am unable to program anything in to the controller. if i try to program, i am getting this error like "Failed to read CPUID for Cortex device."
Tools I am using
IDE: IAR Embedded Workbench
Debugger: Segger J-Link Base
Controller: MK60FN1M0VLQ12
Please let me know, how to solve this issue as early as possible.
Thank you.
-Rajkumar
FelipeGarcia
Hello Rajkumar,
Could you please try to unlock the device by using J-Link commander? Please refer to the following link.
https://community.nxp.com/thread/458914
Felipe
rajkumar_yerraj
Hi Felipe,
Thanks alot. It worked by unlocking it.
-Rajkumar
