Help with a FRDM-KL25Z file download problem?
699 次查看
charlespalmer
I am having trouble copying files to my FRDM-KL25Z boards. When it works a dialog box briefly appears saying "Copying 1 item" and the transfer is successful and the program starts running. In the failure mode the dialog box does not appear, the file name appears instantly in the FRDM-KL25Z Windows Explorer window, and the small LED associated with the OpenSDA interface flashes quickly - 7 or 8 flashes and a pause - repeatedly.
This behaviour is intermittent. I cannot see a pattern. I get the same result with several FRDM boards, with two laptops (both Windows 7). I have the latest PE Micro OpenSDA firmware loaded and the latest USB drivers on both machines.
I believe the FRDM-KL25Z hardware is working as (a) the boards always enumerate as FRDM-KL25Z disk drives, (b) I have no trouble updating OpenSDA firmware and (c) even if the download fails the previously loaded KL25Z
firmware continues to run.
It feels like a device driver fault or a USB fault, or perhaps a fault with the connection between the two processors on the FRDM board. Has anyone else seen this problem? How do I fix it? Help!
标记 (2)
521 次查看
BlackNight
it could be multiple reasons, the ones I have seen the most are:
- Win 8.x (but you say you are using Win7, so this should be fine)
- virus scanner
- using of a file commander/accelerator ==> use the DOS shell copy command instead.
see FRDM Board not responding? Check your Virus Scanner! | MCU on Eclipse
