I am laying out a board using the MK02FN128VLH10. During testing, I want to load my application by using the pre-programmed Kinetis FlashLoader that should be present on the chip.
As I was digging through the documentation, I came across an error in the reference manual, listing the incorrect peripherals for this chip.
K02F Sub-Family Reference Manual
Supports: MK02FN128VLH10, MK02FN128VLF10, MK02FN128VFM10, MK02FN64VLH10, MK02FN64VLF10, MK02FN64VFM10
Document Number: K02P64M100SFARM Rev. 1, 7/2014
http://cache.freescale.com/files/microcontrollers/doc/ref_manual/K02P64M100SFARM.pdf
On page 239, table 13-1 lists the “Kinetis Flashloader Peripheral Pinmux”
PTE0/PTE1 for the UART1 TX/RX looks fine.
However, this chip family does not have I2C1 nor SPI1.
And the Port C & D pins listed in the table on page 239 don’t have the corresponding I2C or SPI hardware.
(This pinout image was cut from the table starting on page 178 of the same manual.)
Does anyone know which pins are enabled for SPI and I2C, in the FlashLoader pre-programmed in the factory?
Andy
解決済! 解決策の投稿を見る。
Hi Andy,
As you previously mentioned the Reference Manual is incorrect and we are actively working towards updating that with our Technical Documentation Team. Many apologies. The correct pinout should be as follows:
Port | Signal |
PTC3 UART1_TX
PTC4 UART1_RX
PTB0 I2C0_SCL
PTB1 I2C0_SDA
PTE16 SPI_PCS0
PTE17 SPI_SCK
PTE18 SPI_SOUT
PTE19 SPI_SIN
Please make your design based on the above pinout. The signals highlighted in bold are the only signals that will be available at this time as we have also have an errata against the MCU. The new errata that we will be publishing in the next week or so is listed below.
Errata Description:
The UART and I2C peripherals are not supported by the Kinetis Flashloader based on the following table:
If you have any additional questions, please do not hesitate to ask.
Again, our apologies for any inconvenience that this may have caused.
Carlos
Hi Andy,
Port | Signal |
PTC3 UART1_TX
PTC4 UART1_RX
PTB0 I2C0_SCL
PTB1 I2C0_SDA
PTE16 SPI_PCS0
PTE17 SPI_SCK
PTE18 SPI_SOUT
PTE19 SPI_SIN
Errata Description:
Carlos
Thanks for the response, Carlos.
This is exactly what I needed to know, and I can still swap pins around on the schematic, so it is not a big deal.
Take care,
Andy
