I need to run an eye pattern test on a Kinetis board, but the SetFeature testmode request doesn't seem to work
Hi Larry:
I assume you are testing this feature on device mode.
If yes, I would suggest you enable below macro and try it again.
/*! @brief Whether device compliance test is enabled. If the macro is enabled,
the test mode and CV test macroes will be set.*/
#define USB_DEVICE_CONFIG_COMPLIANCE_TEST (0U)
change to
#define USB_DEVICE_CONFIG_COMPLIANCE_TEST (1U)
Have a nice day!
