I would like to use a Kinetis K60_100 mcu, MK60DN512VLL10.
In the K60 datasheet I read "Ethernet controller with MII and RMII interface to external PHY". But the phisical RX/TX pin to PHY are only two RXD0, RXD1 and TXD0,TXD1. It should be 0:3.
Indeed when I implement the Ethernet component on the Processor Expert, selecting interface MII, I had the following error: "target processor does not contain peripheral".
What I do not understand?
Bless you !
解決済! 解決策の投稿を見る。
Luca
The K60 supports MII Ethernet connection but you will need to chose a package with 144 pins for these options to be available.
The 100 and 121 pin packages lead-out only the RMII pins.
Mark
Kinetis: http://www.utasker.com/kinetis.html
K60: http://www.utasker.com/kinetis/TWR-K60N512.html / http://www.utasker.com/kinetis/TWR-K60D100M.html / http://www.utasker.com/kinetis/TWR-K60F120M.html
For the complete "out-of-the-box" Kinetis experience and faster time to market
:smileyinfo: Out-of-the-box support for 46 Kinetis boards and 10 IDEs (460 combinations from a single code source with no porting required)
Luca
Mark
