I have two FRDM boards, and both exhibit the same behavior. If I run the sample programs provided by Freescale, using the IAR toolchain, they generally seen to to do what they are supposed to. However - I have tried a variety of small projects that use the FTM, and all do the same thing - when I build and debug, the debugger interface comes up as expected, and I click the "run" button. Nothing happens on the FRDM board. If I click the"halt" button on the debugger, it is always stalled at one of two places - either the "default isr" in vectors.c, or whatever the FIRST line of code is that calls an FTM setting.
For example, I have a line: FTM0_MODE = 4; If this is the first call to the FTM, the program will stall/crash here. If I click the halt button, it will stop at this line. If I click the single-step enter button, the debugfger shows a 'run" condition (i.e. it doesn't step, it's as if I clicked the "run" button) and if I click "halt" again, it will be at the start of that line. If I switch to the assembler mode, and click the single step enter button, it will immediately jump to the default_isr in vectors.c, and then alternate between the default_isr function and the LAST line of the assembler function (STR R1, [R0]).
If I comment out the FTM0_MODE line, then the program will run until it encounters another FTM access, then stall in the same way.
I am totally stumped here, and need some help, as my ultimate application depends very heavily on the FTM. Below is a sample of what I'm trying:
/* timer_int_setup.c tests various timer interrupt & counting functions */
#include "common.h"
#include "ftm.h"
#include "wdog.h"
//#include "rtc.h"
int main (void)
uint16_t counter;
uint32_t temp;
wdog_disable();
typedef struct
uint8_t Port0;
uint8_t Port1;
uint8_t Port2;
uint8_t Port3;
} fourBytes;
typedef struct
uint16_t dbyte0;
uint16_t dbyte1;
} twoDbyte;
union {
fourBytes portBytes;
twoDbyte port16;
uint32_t portWord;
}PORTA;
temp = FTM0_FMS; WILL STALL HERE, UNLESS COMMENTED OUT
FTM0_MODE = 4; // set WPDIS bit WILL STALL HERE, UNLESS COMMENTED OUT
GPIOA_PDDR = 0xffffffff; /* all ones for outputs */
counter = 0;
FTM0_SC = 0x0000000f; // set for system clock, /128 WILL STALL HERE, UNLESS COMMENTED OUT
while (1)
PORTA.portWord = GPIOA_PDOR;
PORTA.port16.dbyte0 = counter;
GPIOA_PDOR = PORTA.portWord;
counter = FTM0_CNT; WILL STALL HERE, UNLESS COMMENTED OUT
if (counter == 100)
// toggle bit 0 of GPIOA
GPIOA_PTOR = 00000001;
已解决! 转到解答。
Sounds like you haven't enabled the clock for FTM0, so you get a bus-fault on any access, that may take effect immediately or 'after a couple clocks' with Cortex write-buffering.
Yes, THAT clock! Sorry I wasn't more explicit (and more timely!). That 'enable' powers-up the peripheral and brings the registers into the bus-space (as well as the actual clocking of internal 'flops').
