Cutting traceD0 and tracdD1 (PA10 & PA9) on Tower to control MII Ethernet. Problems?
504 次查看
cavebiker
Contributor V
Has anyone done this? and are there any issues?
I'm using a PEmicro Multilink Universal with a 20 pin connector to Jtag on a K70 tower System (I think is the same for any Kx Tower System)
I plan to just cut these 2 traces to the Jtag so I can use them to talk to a KSZ8051MNL MII-PHY. Fingers crossed.
Thanks for the look
Cheers,
Tom
标记 (3)
383 次查看
cavebiker
Contributor V
This seems to be working fine :smileyhappy:
384 次查看
cavebiker
Contributor V
