CAN BUS CALCULATOR TIMING BIT
1,729 次查看
carrielbr
how to calculate the bit time parameters can the network?
标记 (3)
1,044 次查看
vfilip
seems that CAN timing calculator does not work properly in new Tabs view. When you swithc to old inspector you should get correct functionality.
#1 Switch to old inspector
#2 Run calculator
best regards
Vojtech Filip
1,044 次查看
Hui_Ma
There is an application note about CAN bit timing, please check here for the detailed info.
I checked Processor Expert tool provides Auto Select CAN bit timing parameters, customer just need to set the CAN baud rate.
Wish it helps.
Ma Hui
1,045 次查看
vfilip
#2 Run calculator
best regards
Vojtech Filip
