I am using FRDM DEV BRD KEAZ128 and S32. I am writing a code where PIT gives interrupt every 1s and starts ADC conversion. But I am not waiting in while loop for COCO bit to set 1. I am enabling ADC interrupt and doing some simple math in main() in for(;;) loop.
But the problem is that ADC interrupt does not show up. I know that PIT interrupts works. But I do not understand how to trigger ADC (adc interrupt and start adc conversion) after PIT interrupt. Could you help me here?
my main loop:
int main(void)
init_UART();
ADC_Init(10,2); //ADC_init ( channel,mode)
Enable_ADC_Interrupt();
init_pit_0 ();
init_IRQs(); /* Initialize PIT interrupts */
for(;;){
if (ready_flag==1)
ADC_accumulator+= ADC_Result ; // read ADC value and add total
dec--; // update decimation counter
GPIOB_PTOR |= (1<<PTH1);
ready_flag=0;
if (dec==0)
dec=16; // reset counter
My_ADC_Result= ADC_accumulator>>2;// 14bit value
My_ADC_Result=My_ADC_Result * 5000; // ADC value times 5000mV
My_ADC_Result=My_ADC_Result>>14; // converts ADC value to mV
print_adc_value= My_ADC_Result; // writes ADC value to uint16_t variable for printf()
printf("\nADC= %d",print_adc_value ); // print to terminal ADC value in mV
ADC_accumulator=0;
My_ADC_Result=0;
print_adc_value =0;
return 0;
my PIT.C :
/* Initialize PIT to generate interrupt every... */
void init_pit_0 (void) {
SIM_SCGC |= SIM_SCGC_PIT_MASK; /* enable clock for PIT*/
PIT_MCR= 0x0; /* Turn on PIT module, Freeze disabled */
PIT_LDVAL0 |= 2400000 - 1; /*PIT0: Load value to count 24MHz bus clocks */
/* if bus clock 24MHz it is equal to 1s */
//PIT_LDVAL0 |= 750 - 1; /* for 32kHz sampling freq = 32.25us */
PIT_TCTRL0 |= PIT_TCTRL_TIE_MASK ; /* Enable interrupt */
PIT_TCTRL0 |= PIT_TCTRL_TEN_MASK; /* PIT0: Start timer */
void init_IRQs (void) {
NVIC_ClearPendingIRQ(PIT_CH0_IRQn); /* Clear any Pending IRQ for PIT (#22) */
NVIC_EnableIRQ(PIT_CH0_IRQn); /* Set Enable IRQ for PIT */
NVIC_SetPriority(PIT_CH0_IRQn,0); /* Set Priority for PIT */
/* Initialize PIT interrupt handler */
void PIT_CH0_IRQHandler (void) {
PIT_TFLG0 |= PIT_TFLG_TIF_MASK ; /* Clear PIT0 clear flag/acknowledge */
//ADC_Result = ADC_R;
//ADC_Result= ADC_Read(10);
//ready_flag=1; //ready flag
my ADC.C
void ADC_Init (uint8_t channel, uint8_t mode){
SIM_SCGC |=SIM_SCGC_ADC_MASK ; /* Enable bus clock for ADC */
ADC_SC3 |= ADC_SC3_ADICLK(0b00); /* Bus clock selected */
ADC_SC2 |= 0x00; /* Software Conversion trigger, disable compare function*/
ADC_SC1 = 0 ;
ADC_SC1|= ADC_SC1_AIEN_MASK; /*Conversion complete interrupt enabled */
ADC_SC1 &= ~ADC_SC1_ADCH_MASK; /* Clear any prior ADCH bits*/
ADC_APCTL1 |= ADC_APCTL1_ADPC(1<<channel); /* Channel selection */
ADC_SC3 = ADC_SC3_MODE(mode); /* Select 0-8bit,1-10bit,2-12 bit mode operation */
uint16_t ADC_Read(uint8_t channel)
ADC_SC1 |= ADC_SC1_ADCH(channel); /* Select channel to read */
while(!(ADC_SC1 & ADC_SC1_COCO_MASK)); /* Wait conversion to complete */
return ADC_R; /* Return ADC value */
/* Initialize ADC interrupts when conversion finished */
void Enable_ADC_Interrupt(void) {
NVIC_ClearPendingIRQ( ADC_IRQn ); /* Clear any Pending IRQ for ADC (#15) */
NVIC_EnableIRQ( ADC_IRQn ); /* Set Enable IRQ for ADC */
NVIC_SetPriority( ADC_IRQn ,0); /* Set Priority for ADC */
ADC_SC1 |=ADC_SC1_AIEN_MASK; /*Conversion complete interrupt enabled */
void ADC_IRQHandler (void) {
ADC_Result = ADC_Read(10);
解決済! 解決策の投稿を見る。
That ADC_Read function seems to be used for polling mode of ADC.
The ADCH bits in ADC_SC1 register can be used to change ADC channel.
If you don't need to change ADC channel, the ADCH bits can be set in ADC_Init function.
If you need to change ADC channel, please refer the function below:
The PIT channel0 overflow will trigger ADC module start sample the signal of that channel.
So you can direct read the ADC_R in your ADC(Conversion Complete) interrupt function. See below:
ADC_Result = ADC_R;
ready_flag=1;
Robin
Hi Irmantas Budrys,
Please read the "24.4.3 Hardware trigger" of KEA128RM.pdf. See below:
When hardware trigger is selected, a ADC conversion is initiated following the assertion of the ADHWT input.
And you need selects "PIT channel0 overflow" as the ADC hardware trigger source.
Robin
Hello Robin,
Thank you for your answer, it is really helpful. But I think it answers only half of my question.
When ADC is triggered conversation takes around 4us. So instead waiting in while() loop (function ADC_Read() below) until conversation is completed I would like to do something useful in my main() function.
You explained me how to trigger ADC, but I still do not understand how to read ADC value after ADC interrupt occurred?
IB
ADC_Result = ADC_R;
ready_flag=1;
Robin
