the problem about UART isr
1,276件の閲覧回数
wyflsxy
hello ,it's about the problem about UART ISR
I used to compile environment is KDS3.0
Using a KSDK1.2 and MQX4.2,and my board is frdmk64f
I want to rec data form uart with ISR
but when I install the uart0 isr,
the Interrupt handler is constantly triggered, whatever I have to send or receive data from UART0
I don't know what's the problem
Is it because UART0 is the default input port?
In addition, I want to know why  the code “printf("\ncounter = %d\n", g_isr_data.COUNTER);
could output data to uart0
void new_isr(void *user_isr_ptr)
   MY_ISR_STRUCT_PTR  isr_ptr;
   isr_ptr = (MY_ISR_STRUCT_PTR)user_isr_ptr;
   isr_ptr->COUNTER++;
   /* It is common to chain interrupts */
   /* isr_ptr->OLD_ISR(isr_ptr->OLD_ISR_DATA); */
main_task(){
INT_SYS_EnableIRQ(SW_IRQ);
    /** Demonstration of mqx interrupt installation. Works with vector table placed in RW as well as RO memory **/
    g_isr_data.COUNTER      = 0;
    g_isr_data.OLD_ISR_DATA = _int_get_isr_data(SW_IRQ);
    g_isr_data.OLD_ISR      = _int_get_isr(SW_IRQ);
    /* Install MQX isr routine. This function does not change vector table */
    old_isr = _int_install_isr(SW_IRQ, new_isr, &g_isr_data);
5 返答(返信)
583件の閲覧回数
ivadorazinova
Hi wang yufei,
please what do you use for MCU?
Iva
583件の閲覧回数
wyflsxy
what did you mean?
I want to receive data form uart by interrupt
but,when I install a uart0 interrupt about like "_int_install_isr(SW_IRQ, new_isr, &g_isr_data);"
the interrupt funtion "new_isr()"was constantly triggered, whatever I havn't send or receive data from UART0
Alice_YangHui_Ma
583件の閲覧回数
ivadorazinova
Hi wang,
please take a look at these documents :
How To: Using Interrupt Handlers in MQX with KSDK
or Interrupt handling with PE
Interrupt handling with KSDK and Kinetis Design Studio
I hope this helps.
Iva
583件の閲覧回数
wyflsxy
I saw the demo and found that it need to clear the interrupt flag bit in GPIO interrupt program with "GPIO_DRV_ClearPinIntFlag (kGpioSW2);"
So  did the UART interrupt program also need to clear the interrupt flag ?
however I did not found the clear interrupt flag programe for uart in the API or the  header files?
could you help me?
583件の閲覧回数
wyflsxy
my project is build with ksdk1.2 with out PE,how can I change the "printf" output from UART0 to UART1?
