Why KDS::newlib::malloc() does not call __malloc_lock/unlock functions? Was locking support compiled out?
I can see malloc_r in the map file but no reference to locking functions.
Sergei
解決済! 解決策の投稿を見る。
Hi Sergei,
If you remove nanolibc from the linker options and simply link in libc, then you will find that malloc/free calls __malloc_lock/unlock. Hopefully this helps you.
Martyn
Hi Sergei,
Yes, they are #define'd out in newlib-nano. The paragraph on malloc in newlib-nano below is from MBED:
The memory allocation routines implementation in newlib-nano include references to MALLOC_LOCK and MALLOC_UNLOCK macros. In the standard newlib library, these macros would be weak references to __malloc_lock()
and __malloc_unlock()
routines. A project like gcc4mbed could then provide implementation of these routines to use a mutex to serialize access to the heap. However, in newlib-nano these macros are #define'ed to nothing so this isn't possible.
I hope this helps.
Martyn
Sorry, looks like replies via Thunderbird make it through to the list but all text is stripped. Here we go again:
On 3/26/2015 11:19 AM, Martyn Hunt wrote:
> However, in newlib-nano these macros are #define'ed to nothing ....
Thought as much. Now, newlib makes malloc/free calls behind your back and we do not have any way to protect these hidden calls.
This makes newlib (as it exists in KDS) not safe to use in any multitasking environment.
The only way I see to make it work is to override newlib's malloc/free with protected equivalents. That seems to work for me.
Sergei
Hi Sergei,
Martyn
Martyn,
Thank you for looking into this. However, I believe full newlib is way too bloated for many embedded systems. For me, the better option was to override library malloc/free with FreeRTOS equivalents.
Sergei
hello Sergei,
can you please upload your demo project to showcase your issue? thanks!
Zhang Jun
Do not have a demo project but here are 3 easy steps to reproduce:
1. In KDS import hello_world_frdm22k demo project from KSDK_1.1.0/demos/hello_world/kds/frdmk22f
2. Add calls to malloc/free somewhere in main(), e.g.:
void *p;
p = malloc(10);
if(p)
free(p);
3. Check map file for presence of locking functions:
grep malloc_lock hello_world_frdmk22f.map
Or use text editor if grep is not available.
You will see that locking functions are not there.
If I add my own locking functions using RTOS locking mechanics they will
not get called either.
BTW, problem was solved by overriding library malloc/free with RTOS equivalents
instead of trying to protect them.
Sergei
