Hi i forgot to add the dummy read thats why it was giving random values if we read from the bus now i have changed my code in order to make dummy read and then read now it works fine.... This above code is not from iic driver file. I have written this register read functionality in order to read from register....
uint8_t I2C_MasterRegisterReadWait(I2C_Type *pI2Cx,uint8_t u8SlaveAddress, uint8_t u8RegisterAddress,uint8_t *pRdBuff)
uint8_t u8ErrorStatus=0;
/* send start signals to bus */
u8ErrorStatus = I2C_Start(pI2Cx);
/* send device address to slave */
u8ErrorStatus = I2C_WriteOneByte(pI2Cx,((uint8_t)u8SlaveAddress<<1) | I2C_WRITE);
if( u8ErrorStatus != I2C_ERROR_NULL )
return u8ErrorStatus;
u8ErrorStatus = I2C_WriteOneByte(pI2Cx,((uint8_t)u8RegisterAddress) );
u8ErrorStatus = I2C_RepeatStart(pI2Cx);
u8ErrorStatus = I2C_WriteOneByte(pI2Cx,((uint8_t)u8SlaveAddress<<1) | I2C_READ);
/* if no error occur, received the correct ack from slave
continue to send data to slave
/* dummy read one byte to switch to Rx mode */
u8ErrorStatus = I2C_ReadOneByte(pI2Cx,&pRdBuff[0],I2C_SEND_NACK);
/* send stop signals to bus */
u8ErrorStatus = I2C_Stop(pI2Cx);
Hi with the below code we are trying to read the Who am i register of MAG3310(slave address is: 0x0e) I am trying to read the who am i register (reg address is: 0x07).
I am supposed to read 0xC4 but am getting 0x1D.
Hello
I have check the datasheet of MAG3310 , the data of 0X1D is the read address , so are you sue you checked the data is the register of "Who am i" ?
And i fund in you IIC file , there is a function of " I2C_MasterReadWait()" , if use this function , what about the result ?
Alice
