I'm losing calibration and settings when I power cycle the FMU, what's wrong?
2,153 次查看
nxf58541
I've had to callibrate everything twice now. If plug and unplug the battery then reconnect with USB to QGroundControl all the callibrations are gone?
2,064 次查看
nxf58541
This is an issue with some bad components that were used. New FMUs should not have this problem (unless another batch of bad components appears again).
2,065 次查看
nxf58541
