Hi @YoungWind,
Can you please try to change the value of "rotation center" attribute and check if image needle can point to right position? If the issue persists, please share your needle image with us, then we can try to reproduce the issue and find out the solution..
Zhenhua
Hi @YoungWind,
Thanks for sharing the image, I have tried the image needle, can you please take a look the value of rotate center setting and check if this is the expected effect?
Zhenhua
Hi @YoungWind,
Yes, I rotate the image to the horizontal direction, please see attached image.
Zhenhua
Hi @YoungWind,
Great to see that you implemented the expected effect.
It is a good suggestion to support custom background and center point, we will add the function in roadmap and support in future release. As a workaround, you may use image widget to set the background picture and center point.
Zhenhua
