MC56F87233 programming time - OnCE USB TAP
762件の閲覧回数
albertospagnolo
Hi everyone,
I'd like to know if the programming time I measure is correct.
With a BDM clock of 8333 kHz, while entering debug with a 33490 bytes program I get:
launching:    3 s
connecting:   5 s
downloading: 26 s
(CW MCU 10.7, Win7 64bit)
I'm a bit concerned of the downloading time. Is it a normal time? Can you suggest a way to reduce this time?
Thank you very much.
Kind regards,
Alberto Spagnolo
タグ(1)
4 返答(返信)
531件の閲覧回数
dynapb
Hi Alberto,
Just saw your question.  Yes debugging with download is a pain.
In the past I used a DSC with a built in bootloader and downloaded code over that and then ran the debugger without download and that process was much faster.
Unfortunately the 56F827xx series does not have a bootloader built in.
I am using the 56F82746 and plan on implementing the bootloader in AN4275 to get the same effect (also I want the bootloader for future code updates)
Pete
531件の閲覧回数
albertospagnolo
Hi Peter,
thanks for your feedback.
I agree, debugging with download is a pain and unfortunately my bootloader has to run at 9600 bps because of the application, so it's quite slow anyway.
I think that my best option is to get to the end of this project as soon as possible.
Kind regards,
Alberto
531件の閲覧回数
xiangjun_rong
Hi, Alberto,
From my experience, it is normal to download the code/data with 26s although I can not give the explanation.
Xiangjun Rong
531件の閲覧回数
albertospagnolo
Thank you for your feedback Xiangjun,
I was hoping to be doing something wrong. Debugging with such a programming time is quite painful...
Kind regards,
Alberto Spagnolo
