When i attach USB cable, "Install Device driver" always fails on Windows and no relief even if i give locations for HC9S08JMxx and usbser.sys files
Can you help how to make this link up. Because of this USB connection issue, not able to run any demo applications.
解決済! 解決策の投稿を見る。
Hi, Ankur,
As you know that there is a chip MC9S08 MCU on the power stage board, which is CDC device and can transform SCI protocol to USB so that you can use Freemaster tools to communicate.
I attach the driver and the code run on MC9S08, you can download the USB_SCI_driver.s19 file to MC9S08 from the J9 BDM port on board via Multilink Universal device or BDM Multilink device from PE company.
The USB driver running on PC HC9S08JMxx.inf is attached.
Hope it can help you
XiangJun Rong
Hi, Ankur,
XiangJun Rong
