mcf52259 internal ram battery backup?
557件の閲覧回数
drummer
I know that I read this somewhere but I can't find the reference for it.
A portion of the internal RAM is made non-volatile through the use of a battery connected to vstby.
I remember reading it somewhere. Does anyone know if it is the upper half or lower half that is retained?
Where is the reference for this information?
I am designing another product that may need to use this feature.
Thanks.
タグ(1)
480件の閲覧回数
TomE
Specialist II
Open the Reference Manual. Type "Control-F", search for "standby" and the first match will tell you.
Tom
2 返答(返信)
481件の閲覧回数
TomE
Specialist II
Tom
480件の閲覧回数
drummer
Thanks I knew I read it somewhere
• On-chip memories
— Up to 64-Kbyte dual-ported SRAM on CPU internal bus, supporting core, DMA, and USB
access with standby power supply support for the first 16 Kbytes
