RTE error (reset) MCF51QE128
5,017 次查看
thm59
I'm trying (for 1 week) to port FreeRTOS on the MCF51QE128 (I have port this on mc9S08QE128 without problem), on the basis of the excellent work of Emmanuel (BugMan) for MCF5213.
When the OS try to start the (Task) scheduler, after a "restore context", a RTE instruction re-load the PC and the SR.
But, the MCF51 resets when trying to execute this RTE.
I attach a picture of the debug session, just before the execution of  the RTE instruction.
The stack frame at 8004DC looks OK (?), The instruction at the  BC4 adress (B4C) is a JSR
Does anyone have a remark or a suggestion (I am relatively beginner)?
Anyone  know other (free) RTOS fort the MCF51QE?
thanks,
thierry
5 回复数
781 次查看
erooll
Hi.
I download last version in your post, but doesn't work in Coldfire V1.
Could you send me your version that works OK in an Coldfire?
Thanks.
781 次查看
thm59
I attach the work I have already done, hoping that someone could help me
thierry
781 次查看
thm59
the same running with MC9S08QE128
thierry
781 次查看
thm59
OK, now it works (FreeRTOS V4.7)
Attached is a simple demo : Toggling 2 leds at different speed on a DEMOQE128.
The code is given without any warranty and can be most probabely improved.
th.
781 次查看
RajahMC
Hi thm59,
Thanks a lot for your port. Works like a charm.
on the QE128. I am using your source as a start
and trying to port it to JM128.
I keep getting an ILLEGAL_BP after starting
the program from the debugger. The only file
that I had to change was main.c
I have my project attached. Can you please
see if I am missing something?
Rajah
