Pin Toggeling MCF5485
1,215件の閲覧回数
marek
Hi Commuity,
i am new to the Coldfire and try to toggel a pin as fast as possible.
The pin toggeling wasn't faster then ~1 Mhz.
I use the Cobra5485 board(from sentec) and thought that the toggling speed should be much faster.
here the source i used to toggel the pins.
Is there no way to toggel the pins faster?
I use the gcc crosscompiler.
#define IPSBAR 0x10000000
#define PAR_PCS3 (IPSBAR + 0xA4C)
#define PAR_PCS2 (IPSBAR + 0xA4D)
#define PAR_PCS1 (IPSBAR + 0xA4E)
#define PDDR_PSC3PSC2 (IPSBAR + 0xA1C)
#define PDDR_PSC1PSC0 (IPSBAR + 0xA1D)
#define PODR_PSC3PSC2 (IPSBAR + 0xA0C)
#define PODR_PSC1PSC0 (IPSBAR + 0xA0D)
int main(void );
void __main(void)
main();
int main(void)
int iCount;
unsigned char ucPortMask;
// set Ports to digital I/O:
(*(unsigned char *)(PAR_PCS3)) = 0x00;
(*(unsigned char *)(PAR_PCS2)) = 0x00;
(*(unsigned char *)(PAR_PCS1)) = 0x00;
// set Ports as outputs:
(*(unsigned char *)(PDDR_PSC3PSC2)) = 0x3F;
(*(unsigned char *)(PDDR_PSC1PSC0)) = 0xC0;
// switch the leds off:
*(unsigned char *)(PODR_PSC3PSC2) = 0x3F;
*(unsigned char *)(PODR_PSC1PSC0) = 0xC0;
ucPortMask = 0x01;
iCount=0;
while(1)
if(iCount==1)
*(unsigned char *)(PODR_PSC1PSC0) = (unsigned char)0x01;
iCount=0;
else
(unsigned char *)(PODR_PSC1PSC0) = (unsigned char)0xC0;
iCount=1;
return(0);
kind regards
marek
384件の閲覧回数
Ciumbia
Well, in order to toggle a pin, it is very convenient to use the XOR function, like:
while (1)
   PORTB ^= 0x01;  //toggles the bit 0 of portb
this should be the fastest in C.
Paolo.
