MCF54452 3.3V 供电,请问其I/O 引脚兼容5V 电平吗?
MCF54452 I/O is not 5V tolerance, which can using 3.3V to 5V level shifting transceiver chip.
Wish it helps.
best regards,
Mike
There are lots of solutions that don't involve using a level shifting chip. For digital or analog inputs you can use resistive dividers. For outputs driving LEDs you can have the I/O pin drive an external FET or transistor. If you're driving something like an SPI, I2C or parallel bus it gets complicated.
Tom
Can the MCF54452 I/O compatible with the 5V level? how to do it ?
