Hello
You can order an upgrade to CodeWarrior Professional edition for ColdFire either on line or through your usual Freescale distributor.
Part number is CWS-MCF-PROED-CX.
Please check following URL:
If you want o order on line, Click on Buy Direct link.
If you want to go through a distributor, select the appropriate region/country in the map.
I hope this helps.
CrasyCat
