Some elements of GUI dialogs not seen in CW 10.3 for PA (QorIQ)
1,681件の閲覧回数
kanatalimzhanov
It seems to be issue of my host operating system.
I can not see some elements of CW dialogs.
Here is two screen shots:
kanat@kanat:~/work/u-boot/CW10.3$ ls *jpg
And my host operating system info:
kanat@kanat:~/work/u-boot/CW10.3$ uname -a
Linux kanat 3.2.0-37-generic-pae #58-Ubuntu SMP Thu Jan 24 15:51:02 UTC 2013 i686 i686 i386 GNU/Linux
kanat@kanat:~/work/u-boot/CW10.3$ lsb_release -d
Description:    Ubuntu 12.04.5 LTS
I have seen same behavior in Demo version of CodeWarrior 10.4.0 for PA.
What can i do to see GUI elements better?
Thanks for help in advance.
タグ(2)
1,422件の閲覧回数
catalindemergia
the "echo $XDG_CURRENT_DESKTOP" command returns "Unity", which is a graphical shell for the
GNOME desktop environment.
regards,
Catalin
12 返答(返信)
1,422件の閲覧回数
catalindemergia
I installed CW PA 10.3 on my "Ubuntu 12.04.4 LTS" system.
The commands I ran in order to install CW were
sudo apt-get install ia32-libs
sudo apt-get install bc
./setuplinux
I took these instructions from the 2.12 section in README.txt.
I could see the checkboxes without doing any other changes.
regards,
Catalin
1,422件の閲覧回数
kanatalimzhanov
Thanks Yiping Wang and lunminliang.
Thanks, Catalin.
Which desktop you are using? KDE or GNOME ?
I will try this way also
"sudo apt-get install ia32-libs
./setuplinux
Meantime checked that in GNOME desktop of Ubuntu 12.04  CW 10.3 dialogs shown correct.
1,423件の閲覧回数
catalindemergia
regards,
Catalin
1,422件の閲覧回数
lunminliang
I am using CW10.3.3 on Ubuntu 14.04 and do not have problem. Have you installed those dependancy as in install_deps.sh?
See mine:
freescale@freescale-sdk:~$ uname -a
Linux freescale-sdk 3.13.0-24-generic #46-Ubuntu SMP Thu Apr 10 19:08:14 UTC 2014 i686 i686 i686 GNU/Linux
freescale@freescale-sdk:~$ lsb_release -d
Description:    Ubuntu 14.04 LTS
1,422件の閲覧回数
kanatalimzhanov
Can not find this file, "install_deps.sh".
In file README.txt no special instructions about Ubuntu
"2.2 Ubuntu 8.04 32bit installation procedure:
   1) Install OS with default settings.
   2) Install CodeWarrior. No dependencies are required.
No words about Ubuntu 12.04 or 14.04
Can you be so please to post that file (install_deps.sh) here?
1,422件の閲覧回数
lunminliang
On my host, the file is right under the CW installation directory.
freescale@freescale-sdk:/opt/Freescale/CodeWarrior_PA_10.3.3$ ls
Cross_Tools  eclipse  install_deps.sh  PA      restore.pl
detect.sh    gnu      jre              remove  uninstall
1,422件の閲覧回数
kanatalimzhanov
I think that you have CW 10.3.3 version (and mine 10.3) make a difference.
Mine here:
kanat@kanat:/opt/Freescale/CodeWarrior_PA_10.3$ ls
Cross_Tools  eclipse  gnu  _jvm  PA  _uninst
Maybe here is a way to upgrade from CW 10.300 to 10.3.3 ?
I found a workaround for this little inconvenience:
*) when Target_properties_Dialog or Reset_Dialog appears one may scroll-unscroll cores list (where e500mc-0 ... e500mc-7 listed)
   after this elements of GUI seen much better. Here is a picture.
1,422件の閲覧回数
yipingwang
Hello Kanat Alimzhanov,
If the eclipse plugin cannot be displayed correctly on Ubuntu OS, there is a workaround would be helpful for you.
Please change the appearance from System->Preference->Appearance, and select "clearlooks".
Yiping
1,422件の閲覧回数
kanatalimzhanov
I have a try on my Ubuntu
kanat@kanat:~/P4080DS/Uboot$ uname -a
kanat@kanat:~/P4080DS/Uboot$ lsb_release -d
Next steps:
Settings --> System_settings --> Application_appearance --> Style --> Widget_style -->  change from "Oxygen" to "clearlooks".
A lot of changes in appearance of windows but no help to resolve my problem.
README file of CW 10.3  say that CW works on Ubuntu with default settings.
Maybe i should use default desktop system of ubuntu GNOME instead of KDE?
(now i use KDE desktop).
I will try to install GNOME desktop and write here about results.
1,422件の閲覧回数
lunminliang
Thanks for sharing.
> I think you need to install from the new installer.
1,422件の閲覧回数
kanatalimzhanov
"Have you installed those dependancy as in install_deps.sh?"
I am unsure. Remember that installed something like when start to use QCS (QorIQ Configuration Suite).
I will recheck, and maybe upgrade my Ubuntu.
Thanks.
1,422件の閲覧回数
lunminliang
In my impression, when I was installing CodeWarrior, it tells the dependency has already been installed successfully.
