Conditional Compiling
4,439 次查看
timotay01
Is there a way to setup a conditional compile for the entire project typically done in a make file with -D ?
标记 (1)
4 回复数
851 次查看
CrasyCat
Specialist III
Hello
Which processor are you targeting (HC08, HC12, ...)?
Are you planning to build from the IDE or from a make file?
CrasyCat
851 次查看
timotay01
Sorry, build from IDE, and part is CF5208
851 次查看
CrasyCat
Specialist III
If you are using CodeWarrior for Coldfire V6.x you can just add the #define corresponding to the macro you want to define in the target settings "C/C++ Preprocessor Panel".
This panel can be found in the target setting dialog. Press ALT + F7 to open the dialog.
If you are using an older version of the tools, you have to go through a prefix file.
A prefix file is a header file which is included in each ANSI C source file.
Macros are defined there using #define and you specify the name of your prefix file in the target "C/C++ Language Panel".
I hope this helps.
CrasyCat
851 次查看
timotay01
Yes that was what I was looking for thanks.
